メインコンテンツにスキップ
Acer Iconia Tab B1 Factory Hard Reset/Password Removal
ビデオの概要
  1. Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 1、 3の画像 1 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 1、 3の画像 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal, Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 1、 3の画像 3
    • From the reset hole we can make reset without erasing data.
  2. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 2、 3の画像 1 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 2、 3の画像 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 2、 3の画像 3
    • Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
  3. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 3、 2の画像 1 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 3、 2の画像 2
    • Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
    • Pressing the Power On key too quickly may turn off the tablet screen. You'll need to press and hold for about a second to select [SD Update Image Mode].
    Hi when i make it, fastboot mode was in the screen
    Sihem Smiti - 返信
  4. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 4、 3の画像 1 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 4、 3の画像 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 4、 3の画像 3
    • Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
  5. Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 5、 3の画像 1 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 5、 3の画像 2 Acer Iconia Tab B1 Factory Hard Reset/Password Removal: 手順 5、 3の画像 3
    • After restart you will have empty (free of data) device and access to it.
    buen dia la tablet se queda en la pantalla de welcome que hago
    Frank Rondon - 返信
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,278 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
2 件のコメント
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
martinez1816 - 返信
I have the same problem when it came to SD image update mode I get the acer logo and it restarts it does not pass to the android logo it geast restart
Claudiu - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 70,692
