はじめに
Replace the speaker in your Acer Iconia Tab 500.
パーツ
パーツは必要ありません。
  1. To start, gently separate one corner of the case using the black spudger.
    • To start, gently separate one corner of the case using the black spudger.
  2. Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Locate the 4 screws and cable that hold in the two speakers.
    • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
    • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
    • Connector Cable
  5. Carefully remove the connector cable by pushing on the rim of black plastic insert.
    • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  6. Unfortunately, the top speaker is a wedged under the motherboard.
    • Unfortunately, the top speaker is a wedged under the motherboard.
    • To get this speaker out, use the spudger and gently pry it out.
まとめ
ある他の人がこのガイドを完成しました。
Kyle Libby
メンバー登録日: 2014年04月07日
948 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 7-23, Regan Spring 2014 Cal Poly, Team 7-23, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G23
4 メンバー
18のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 1,679
