メインコンテンツにスキップ
Acer Iconia Tab A200 Speaker Replacement
必要な工具と部品
  1. Acer Iconia Tab A200 Speaker Replacement, Battery: 手順 1、 2の画像 1 Acer Iconia Tab A200 Speaker Replacement, Battery: 手順 1、 2の画像 2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Speaker Replacement: 手順 2、 2の画像 1 Acer Iconia Tab A200 Speaker Replacement: 手順 2、 2の画像 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Speaker Replacement: 手順 3、 2の画像 1 Acer Iconia Tab A200 Speaker Replacement: 手順 3、 2の画像 2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Speaker Replacement: 手順 4、 2の画像 1 Acer Iconia Tab A200 Speaker Replacement: 手順 4、 2の画像 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Speaker Replacement: 手順 5、 2の画像 1 Acer Iconia Tab A200 Speaker Replacement: 手順 5、 2の画像 2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
  6. Acer Iconia Tab A200 Speaker Replacement, Speaker: 手順 6、 2の画像 1 Acer Iconia Tab A200 Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
  7. Acer Iconia Tab A200 Speaker Replacement: 手順 7、 1の画像 1
    • Once the screws are removed, lift up on the speakers to remove them from the case.
  8. Acer Iconia Tab A200 Speaker Replacement: 手順 8、 1の画像 1
    • Once you have removed the speakers from the case, disconnect the speakers from the motherboard by pulling the cable out horizontally. Do not pull up on the cable.
終わりに
作成者
2人の作成者と共同で作成されました。
Steve Chiu
メンバー登録日: 03/11/16
253 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G5
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 289
