この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The Acer Iconia Tab A200 has a 10.1" Touchscreen display.
必要な工具と部品
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Using the plastic opening tool gently lift up the charging component out of its slot in the case.
Lift up on the microphone cable to lift the microphone component away from the case.
After removing the battery use a Phillips head #00 screwdriver to remove the 3.0 mm screws holding the dual speakers in place.
Using the plastic opening tool unplug the green cable by placing the tool under where the cable meets the plug and lifting up.
After unplugging the green cable remove the black tape that secures the green cable to motherboard.
4 の人々がこのガイドを完成させました。
2 件のコメント
Looking forward to fixing this tablet a friend had given up on then gave to me. So funny how easily ppl give up!Thank you for this spectacular set of directions. Looks like it will be the one that works for the tablet I have.
MichelleE1 - 返信
how can i tell if there is any water damage?
