この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The Acer Iconia Tab uses a Li-Po 3260 mAh battery that is screwed into the device.
必要な工具と部品
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
ある他の人がこのガイドを完成しました。
2 件のコメント
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
