メインコンテンツにスキップ
Acer Iconia Tab A200 Battery Replacement
必要な工具と部品
  1. Acer Iconia Tab A200 Battery Replacement, Battery: 手順 1、 2の画像 1 Acer Iconia Tab A200 Battery Replacement, Battery: 手順 1、 2の画像 2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Battery Replacement: 手順 2、 2の画像 1 Acer Iconia Tab A200 Battery Replacement: 手順 2、 2の画像 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Battery Replacement: 手順 3、 2の画像 1 Acer Iconia Tab A200 Battery Replacement: 手順 3、 2の画像 2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Battery Replacement: 手順 4、 2の画像 1 Acer Iconia Tab A200 Battery Replacement: 手順 4、 2の画像 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Battery Replacement: 手順 5、 2の画像 1 Acer Iconia Tab A200 Battery Replacement: 手順 5、 2の画像 2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jaimie Payne
メンバー登録日: 03/06/16
477 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 5-5, Landers Spring 2016 UMass Dartmouth, Team 5-5, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G5
3 メンバー
6のガイドは作成済み
2 件のコメント
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
Michael Burlovich - 返信
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
Gloria Regester - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,763
