メインコンテンツにスキップ
Acer Iconia Tab 8 A1-840 Speaker Replacement
必要な工具と部品
  1. Acer Iconia Tab 8 A1-840 Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • Power off the device
    • Remove any cables that might be connected to your device
    • Make sure the device is placed on a flat surface with the display screen facing up
  2. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 2、 1の画像 1
    • Wedge the plastic opening tool in between the display screen and back panel
    • Do not apply too much pressure in order to avoid cracking the screen
  3. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 3、 1の画像 1
    • Carefully separate the display from the back panel
  4. Acer Iconia Tab 8 A1-840 Speaker Replacement, Battery: 手順 4、 1の画像 1
    • Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
  5. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 5、 1の画像 1
    • Use the flat end of the spudger to pry up and remove the battery cable.
  6. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 6、 1の画像 1
    • Use the flat side of the heavy duty spudger to lift the small black plastic flap.
  7. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 7、 1の画像 1
    • Use fingers to pull the Zero Insertion Force (ZIF) cable from the motherboard.
  8. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 8、 1の画像 1
    • Use fingers to remove the smaller adjacent ZIF cable from the motherboard.
  9. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 9、 1の画像 1
    • Use the flat end of the spudger to pry the battery up from all edges, and remove it from the back panel.
    • There is adhesive behind the battery that holds it in place. Be sure to pry slowly and carefully when removing the battery.
  10. Acer Iconia Tab 8 A1-840 Speaker Replacement, Speaker: 手順 10、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use tweezers or the flat end of the spudger to carefully pull the connection loose.
  11. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 11、 1の画像 1
    • Use the pointy end of the spudger to remove the black tape holding the wires in place and completely free the wires.
  12. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 12、 1の画像 1
    • Use a 5mm nut driver and Philips#000 bit to remove the four 1.5mm screws.
  13. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 13、 1の画像 1
    • Remove the speakers after unscrewing the screws.
  14. Acer Iconia Tab 8 A1-840 Speaker Replacement: 手順 14、 1の画像 1
    • Use spudger to loosen the wire and free the speaker.
終わりに
作成者
5人の作成者と共同で作成されました。
Claire Posadas
メンバー登録日: 10/18/16
396 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team 1-1, Rose Fall 2016 UW Tacoma, Team 1-1, Rose Fall 2016人のメンバー
UWT-ROSE-F16S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 764
