メインコンテンツにスキップ
Acer Iconia B1-720 Motherboard Replacement
必要な工具と部品
  1. Acer Iconia B1-720 Motherboard Replacement, Rear Case: 手順 1、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement, Rear Case: 手順 1、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement, Rear Case: 手順 1、 3の画像 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Motherboard Replacement: 手順 2、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 2、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement: 手順 2、 3の画像 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Motherboard Replacement: 手順 3、 2の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 3、 2の画像 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Motherboard Replacement, Battery: 手順 4、 2の画像 1 Acer Iconia B1-720 Motherboard Replacement, Battery: 手順 4、 2の画像 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Motherboard Replacement: 手順 5、 1の画像 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Motherboard Replacement: 手順 6、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 6、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement: 手順 6、 3の画像 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
  7. Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: 手順 7、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: 手順 7、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement, Microphone/Speaker: 手順 7、 3の画像 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  8. Acer Iconia B1-720 Motherboard Replacement: 手順 8、 2の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 8、 2の画像 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  9. Acer Iconia B1-720 Motherboard Replacement: 手順 9、 2の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 9、 2の画像 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  10. Acer Iconia B1-720 Motherboard Replacement, Motherboard: 手順 10、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement, Motherboard: 手順 10、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement, Motherboard: 手順 10、 3の画像 3
    • Remove the yellow tape covering both ribbons in the two photos shown.
  11. Acer Iconia B1-720 Motherboard Replacement: 手順 11、 2の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 11、 2の画像 2
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  12. Acer Iconia B1-720 Motherboard Replacement: 手順 12、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 12、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement: 手順 12、 3の画像 3
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  13. Acer Iconia B1-720 Motherboard Replacement: 手順 13、 2の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 13、 2の画像 2
    • Use tweezers to gently remove black ribbon from locking mechanism.
  14. Acer Iconia B1-720 Motherboard Replacement: 手順 14、 3の画像 1 Acer Iconia B1-720 Motherboard Replacement: 手順 14、 3の画像 2 Acer Iconia B1-720 Motherboard Replacement: 手順 14、 3の画像 3
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kervis Boston
メンバー登録日: 03/18/15
479 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G1
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,411
