メインコンテンツにスキップ
Acer Iconia B1-720 Microphone/Speaker Replacement
必要な工具と部品
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: 手順 1、 3の画像 1 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: 手順 1、 3の画像 2 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: 手順 1、 3の画像 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 2、 3の画像 1 Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 2、 3の画像 2 Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 2、 3の画像 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 3、 2の画像 1 Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 3、 2の画像 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: 手順 4、 3の画像 1 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: 手順 4、 3の画像 2 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: 手順 4、 3の画像 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 5、 2の画像 1 Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 5、 2の画像 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 6、 2の画像 1 Acer Iconia B1-720 Microphone/Speaker Replacement: 手順 6、 2の画像 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
終わりに
作成者
2人の作成者と共同で作成されました。
Phillip Keavey
メンバー登録日: 03/17/15
319 ポイント
2のガイドは作成済み
チーム
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G1
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 686
