メインコンテンツにスキップ
Acer Iconia B1-710 Tablet Camera Replacement
必要な工具と部品
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: 手順 1、 3の画像 1 Acer Iconia B1-710 Tablet Camera Replacement, Battery: 手順 1、 3の画像 2 Acer Iconia B1-710 Tablet Camera Replacement, Battery: 手順 1、 3の画像 3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: 手順 2、 3の画像 1 Acer Iconia B1-710 Tablet Camera Replacement: 手順 2、 3の画像 2 Acer Iconia B1-710 Tablet Camera Replacement: 手順 2、 3の画像 3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: 手順 3、 1の画像 1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: 手順 4、 2の画像 1 Acer Iconia B1-710 Tablet Camera Replacement, Camera: 手順 4、 2の画像 2
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: 手順 5、 2の画像 1 Acer Iconia B1-710 Tablet Camera Replacement: 手順 5、 2の画像 2
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: 手順 6、 2の画像 1 Acer Iconia B1-710 Tablet Camera Replacement: 手順 6、 2の画像 2
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: 手順 7、 3の画像 1 Acer Iconia B1-710 Tablet Camera Replacement: 手順 7、 3の画像 2 Acer Iconia B1-710 Tablet Camera Replacement: 手順 7、 3の画像 3
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: 手順 8、 1の画像 1
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: 手順 9、 3の画像 1 Acer Iconia B1-710 Tablet Camera Replacement: 手順 9、 3の画像 2 Acer Iconia B1-710 Tablet Camera Replacement: 手順 9、 3の画像 3
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
終わりに
To reassemble your device, follow the above instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Ryan Weber
メンバー登録日: 03/26/17
358 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S3-G5, Baechle Spring 2017 IUPUI, Team S3-G5, Baechle Spring 2017人のメンバー
IUPUI-BAECHLE-S17S3G5
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 352
