はじめに
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Please SUBSCRIBE to my channel ツ
パーツ
パーツは必要ありません。
ビデオの概要
  1. Switch-off the tablet. If you have a memory card inside, don't forget to remove it! Use a cutter and a plastic tool to remove the back cover.
    • Switch-off the tablet.
    • If you have a memory card inside, don't forget to remove it!
    • Use a cutter and a plastic tool to remove the back cover.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Disconnect the battery connector. The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it . The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
    • Disconnect the battery connector.
    • The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
  4. Li-on Batteri Pack, 3.8V, 2640mAh
まとめ
2 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
162,554 ポイント
304のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
280 メンバー
784のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 20
過去 30 日: 133
今までの合計 18,071
