メインコンテンツにスキップ
Acer Iconia A1-830 Rear Facing Camera Replacement
必要な工具と部品
  1. Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: 手順 1、 2の画像 1 Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: 手順 1、 2の画像 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 2、 2の画像 1 Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: 手順 3、 2の画像 1 Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: 手順 3、 2の画像 2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 4、 1の画像 1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 5、 2の画像 1 Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 5、 2の画像 2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Rear Facing Camera Replacement, Rear Facing Camera: 手順 6、 1の画像 1
    • Remove the piece of black tape covering the rear facing camera ribbon cable connector.
  7. Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 7、 2の画像 1 Acer Iconia A1-830 Rear Facing Camera Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Lift up the small white lever on the the ribbon cable connector with the metal tweezers to remove the ribbon cable.
    • Lift out the rear facing camera from the plastic frame with the metal tweezers.
終わりに
作成者
3人の作成者と共同で作成されました。
Brendan Coveney
メンバー登録日: 10/18/15
593 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015人のメンバー
UMASSD-CATANIA-F15S4G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 428
