はじめに
Having connection issues with your WiFi? Is it dropping or the signal is very weak? Your WiFi card may be faulty or past it's prime. This guide will take you through the replacement of the WiFi card.
必要な工具と部品
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Locate the Wi-Fi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
Carefully lift the white and black coaxial cables up and forward to disconnect the them from the Wi-Fi card.
