はじめに
Is your laptop overheating? Are you hearing strange noises coming from inside the case? It may be time to replace your CPU Cooling fan.
必要な工具と部品
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Locate the CPU cooling fan in the upper left corner of the laptop.
Using a Phillips #0 screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
Place the tips of the ESD safe pointed tweezers between the plug and the socket of the fan connection.
Gently push the tweezers to the left to disconnect the fan plug.
Move the fan connector and its wires to free them from the motherboard and the Wi-Fi card.
