メインコンテンツにスキップ
Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement
必要な工具と部品
  1. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Bottom Panel: 手順 1、 1の画像 1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 2、 1の画像 1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Battery: 手順 3、 1の画像 1
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 4、 2の画像 1 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 4、 2の画像 2
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 5、 1の画像 1
    • Lift the battery out by pulling upward.
  6. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: 手順 6、 2の画像 1 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Lift the retaining flaps of the two ZIF connectors into the upright position using the flat end of the spudger.
    • Unplug the tabs from the connectors by gently pulling them out with the tweezers.
  7. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 7、 2の画像 1 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 7、 2の画像 2
    • Slide back both sides of the locking mechanism of the touchpad using the narrow end of the spudger.
    • Unplug the trackpad wire by gently pulling it out of the connector with the tweezers.
  8. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 8、 1の画像 1
    • Unplug the audio connector from the motherboard with the tweezers.
    • Be sure to pull the plug by holding it at the base, not yanking on the wires, as this could damage the device.
  9. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 手順 9、 1の画像 1
    • Pop the speakers off of the device by hand.
    • They are held on only by a mild adhesive and should come off easily.
終わりに
作成者
6人の作成者と共同で作成されました。
Harrison DeWitt
メンバー登録日: 04/26/17
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G2
4 メンバー
12のガイドは作成済み
コメント 1 件
Hi, do you know how to replace the microphone on this chromebook?
Álvaro Guzmán Parrochia - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 22
今までの合計 653
