はじめに
If the LED lights of your Acer Chromebook R11 CB5-132T-C1LK are not functioning properly, this guide will detail how to access and remove the LED board for replacement.
必要な工具と部品
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
この手順で使用する道具:Tweezers$4.99
Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
Pull the ribbon cable from the ZIF connector using tweezers.
もう少しです!
終わりに
