メインコンテンツにスキップ
Acer Chromebook R11 C738T-C44Z Speakers Replacement
必要な工具と部品
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 手順 1、 3の画像 1 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 手順 1、 3の画像 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 手順 1、 3の画像 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: 手順 2、 2の画像 1 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: 手順 2、 2の画像 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 3、 1の画像 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 4、 1の画像 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: 手順 5、 2の画像 1 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: 手順 5、 2の画像 2
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 6、 3の画像 1 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 6、 3の画像 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 6、 3の画像 3
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 7、 3の画像 1 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 7、 3の画像 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 7、 3の画像 3
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 8、 1の画像 1
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 9、 3の画像 1 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 9、 3の画像 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 手順 9、 3の画像 3
    • Gently lift the speakers up and remove the cable from the system.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Connie Hernandez
メンバー登録日: 09/01/21
517 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021人のメンバー
GCC-SAKNEE-F21S1G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 12
今までの合計 108
