メインコンテンツにスキップ
Acer Chromebook R11 C738T-C44Z Motherboard Replacement
必要な工具と部品
  1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 手順 1、 3の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 手順 1、 3の画像 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 手順 1、 3の画像 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: 手順 2、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: 手順 2、 2の画像 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 3、 1の画像 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 4、 1の画像 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: 手順 5、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: 手順 5、 2の画像 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  6. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 6、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  7. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 7、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 7、 2の画像 2
    • Carefully slide the wireless card out of its socket from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 手順 8、 3の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 手順 8、 3の画像 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 手順 8、 3の画像 3
    • Disconnect the LED board ribbon by pulling it out gently.
    • Disconnect the speaker cable.
  9. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 9、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 9、 2の画像 2
    • Disconnect the keyboard ribbon.
    • Slide it out gently to not rip it.
  10. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 10、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 10、 2の画像 2
    • Disconnect the daughterboard ribbon by flipping up the white tab and pulling it out from the motherboard.
  11. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 11、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 11、 2の画像 2
    • Disconnect the touchpad ribbon by lifting up the tab and pulling it out.
  12. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 12、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 12、 2の画像 2
    • Disconnect the sensor cable by pulling it out.
  13. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 13、 3の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 13、 3の画像 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 13、 3の画像 3
    • Disconnect the LCD cable by pinching it and lifting it off the motherboard.
  14. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 14、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 14、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws that hold the hinge down.
  15. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 15、 3の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 15、 3の画像 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 15、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the motherboard.
  16. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 16、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 16、 2の画像 2
    • Slide the opening tool underneath the hinge latch to lift it up.
    • This is to free the motherboard.
  17. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 17、 2の画像 1 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 手順 17、 2の画像 2
    • Grab the motherboard securely to lift and remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Connie Hernandez
メンバー登録日: 09/01/21
517 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021人のメンバー
GCC-SAKNEE-F21S1G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 34
今までの合計 480
