この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Having battery issues? Here's how to replace it!
To avoid generating static between you and the device, you should wear a rubber bracelet. Not doing so could potentially damage your device.
必要な工具と部品
The back cover of the R11 is held into place using 11 screws.
To remove, use a screwdriver appropriate for a JIS 1 screw.
9 の人々がこのガイドを完成させました。
コメント 1 件
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
