メインコンテンツにスキップ
Acer Chromebook R11 Battery Replacement
必要な工具と部品
  1. Acer Chromebook R11 Battery Replacement, Battery: 手順 1、 1の画像 1
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Battery Replacement: 手順 2、 1の画像 1
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Battery Replacement: 手順 3、 1の画像 1
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Battery Replacement: 手順 4、 1の画像 1
    • Remove the battery by pulling upwards.
終わりに
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jermaine Hannans
メンバー登録日: 02/16/17
386 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-2, Kass Spring 2017 USF Tampa, Team 1-2, Kass Spring 2017人のメンバー
USFT-KASS-S17S1G2
4 メンバー
6のガイドは作成済み
コメント 1 件
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
Andre De Guerin - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 27
過去 30 日: 80
今までの合計 9,529
