必要な工具と部品
Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
Gently slide the black ribbon out from its socket and under the white ribbon.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
