必要な工具と部品
First begin by flipping the laptop on its back and having the back cover face you directly.
Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
look for the battery in the bottom half of the computer
Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
Begin by locating the speakers.
Once you have found where the speakers are, direct your attention to the speaker to the left of the mouse pad.
Grab your tweezers and begin disconnecting the wire that connects the speakers to the circuit board on the upper left corner.
Direct your attention back to the speaker that you were first working with in step 5.
Start by pulling up on the speaker, it should simply come right out.
Repeat this for the right speaker.
Once the two speakers are removed, unhook the wires from any clips that may be holding it to the computer.
