メインコンテンツにスキップ
Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement
必要な工具と部品
  1. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 手順 1、 2の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 手順 1、 2の画像 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 2、 1の画像 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: 手順 3、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: 手順 3、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Battery: 手順 3、 3の画像 3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 4、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 4、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 4、 3の画像 3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
  5. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: 手順 5、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: 手順 5、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement, Motherboard: 手順 5、 3の画像 3
    • Remove the yellow tape covering the ribbon cable in the bottom left of the motherboard as shown.
    • Carefully remove the ribbon cable out from the connector.
  6. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 6、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 6、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 6、 3の画像 3
    • Fold up the grey cover to release the ribbon cable in the bottom right of the board as shown.
    • Carefully pull out the ribbon cable from the port by the blue tape.
  7. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 7、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 7、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 7、 3の画像 3
    • Fold up the white cover to release the ribbon cable in the top left of the board as shown.
  8. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 8、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 8、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 8、 3の画像 3
    • Fold up the grey cover to release the cable on the top right of the board as shown
    • Carefully pull out the cable from the port.
  9. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 9、 2の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the cable with tweezers as shown along the top of the board.
  10. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 10、 2の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 10、 2の画像 2
    • Carefully pull off both brass connectors from the top left of the board with tweezers as shown.
  11. Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 11、 3の画像 1 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 11、 3の画像 2 Acer Chromebook CB5-312T-K 8Z9 Motherboard Replacement: 手順 11、 3の画像 3
    • Remove the six screws from the board as shown. There are two types of screws here, so be careful to keep them separate for reassembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Robert McCullough
メンバー登録日: 09/25/17
128 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G4, Thompson Fall 2017 University of North Texas, Team S1-G4, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S1G4
4 メンバー
10のガイドは作成済み
7 件のコメント
thanks for the write up! do you know where the bluetooth is on the motherboard? I presume step 10 are the connections to the wifi antennae?
leerandmcnally - 返信
This Chromebook likely uses a dual chip which can be seen in step 10. I’m guessing the chip is a 802.11AC 2x2 MIMO WLAN + Bluetooth 4.0 from looking at the specs.
Blake Klein -
wich is the firmware write protect screw on the motherboard to cheng the os to win10 ??
loudikov - 返信
This is an ARM MT8173 machine, no Windows 10 for this hardware… Win10 for ARM is still on ARM based Surface, and gives poor experience.
Roberto Giuffrè -
Bonjour,
J ai un chromebook CB5-312T quelle carte mère je dois acheter et où mon chromebook ne s allume plus.
Merci
Celine Gaidot - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 31
今までの合計 2,199
