メインコンテンツにスキップ
Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement
必要な工具と部品
  1. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 2、 1の画像 1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 3、 2の画像 1 Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 3、 2の画像 2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 4、 2の画像 1 Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 4、 2の画像 2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement, Daughterboard: 手順 5、 1の画像 1
    • Detach the four cable connectors from the daughterboard.
  6. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 6、 1の画像 1
    • Remove the two silver screws with a Phillips #1 screwdriver.
    • Remove the two black screws with a Phillips #1 screwdriver.
  7. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 7、 2の画像 1 Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 7、 2の画像 2
    • Lift up the metal hinge.
  8. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: 手順 8、 1の画像 1
    • Remove the daughterboard from the laptop.
終わりに
作成者
1人の作成者と共同作成されました。
Ethan Sylvia
メンバー登録日: 03/20/24
351 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024人のメンバー
UMASSD-SANTIN-S24S1G5
3 メンバー
7のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 166
