メインコンテンツにスキップ
Acer Chromebook CB3-431-C5EX Speaker Replacement
必要な工具と部品
  1. Acer Chromebook CB3-431-C5EX Speaker Replacement, Bottom Panel: 手順 1、 1の画像 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 2、 1の画像 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 3、 2の画像 1 Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 3、 2の画像 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Speaker Replacement, Internal Speakers: 手順 4、 1の画像 1
    • Remove the two 4mm Phillips #0 screws securing the speaker.
  5. Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 5、 2の画像 1 Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 5、 2の画像 2
    • Remove the speaker from the computer.
    • Repeat the previous steps to remove the second speaker from the computer.
    • Note that the two speakers are connected by a wire, so you must replace both of them.
  6. Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 6、 2の画像 1 Acer Chromebook CB3-431-C5EX Speaker Replacement: 手順 6、 2の画像 2
    • Disconnect the speaker wire from the circuit board by grabbing the plug by its plastic edges and gently pulling it straight out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Cayley Ho
メンバー登録日: 04/18/17
545 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G3
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,012
