メインコンテンツにスキップ
Acer Chromebook CB3-431-C5EX Motherboard Replacement
必要な工具と部品
  1. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Bottom Panel: 手順 1、 1の画像 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 3、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 3、 2の画像 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Battery: 手順 4、 1の画像 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 5、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 5、 2の画像 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 6、 1の画像 1
    • Carefully lift the entire battery pack out of the laptop.
  7. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the 4.7 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the laptop.
  8. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 8、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 8、 2の画像 2
    • Unplug the black wire connecting the small circuit board to the motherboard.
  9. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 9、 3の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 9、 3の画像 2 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 9、 3の画像 3
    • Lift the respective white and black tabs and slide the ribbon cables out of their connectors.
  10. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 10、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 10、 2の画像 2
    • Carefully remove the display adapter from the motherboard.
  11. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 11、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the black tab connecting the motherboard to the keyboard.
  12. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 12、 2の画像 1 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 手順 12、 2の画像 2
    • Remove the five 4.7 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the two 4.5 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Gently remove motherboard from the laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Graham Caldwell Blondes
メンバー登録日: 09/20/21
133 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 452
