メインコンテンツにスキップ
Acer Chromebook CB3-131-C3KD Track pad Replacement
必要な工具と部品
  1. Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: 手順 1、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: 手順 1、 2の画像 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 2、 3の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 2、 3の画像 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 2、 3の画像 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 3、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 3、 2の画像 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 4、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 4、 2の画像 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 5、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 5、 2の画像 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: 手順 6、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: 手順 6、 2の画像 2
    • Remove the (3) three 7.0mm screws using the J0 screwdriver head.
  7. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 7、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 7、 2の画像 2
    • Unlock the latches on both ends of the ribbon cable, and pull to detach.
    • The ribbon cable will still be attached to the tape.
  8. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 8、 1の画像 1
    • Peel the tape that is on top of the trackpad.
  9. Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 9、 2の画像 1 Acer Chromebook CB3-131-C3KD Track pad Replacement: 手順 9、 2の画像 2
    • Lift the trackpad out of the Chromebook.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ashley Oxner
メンバー登録日: 09/26/17
704 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S11-G1, Passmore Fall 2017 USF Tampa, Team S11-G1, Passmore Fall 2017人のメンバー
USFT-PASSMORE-F17S11G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 399
