メインコンテンツにスキップ
Acer Chromebook CB3-111-C8UB Touchpad Replacement
必要な工具と部品
  1. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: 手順 1、 2の画像 1 Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: 手順 1、 2の画像 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 2、 3の画像 1 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 2、 3の画像 2 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 2、 3の画像 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 3、 2の画像 1 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 3、 2の画像 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Battery: 手順 4、 1の画像 1
    • Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
  5. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 5、 3の画像 1 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 5、 3の画像 2 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 5、 3の画像 3
    • Pull the battery forward to clear the base from its clips.
    • Lift the battery up so that there is room to grab and unplug the bundled cable connector.
  6. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Touchpad: 手順 6、 1の画像 1
    • Use a metal spudger to flip up the white ZIF connector that holds the ribbon cable in place.
    • Unplug the black ribbon cable from the track pad assembly.
  7. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 7、 2の画像 1 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 7、 2の画像 2
    • Use a Phillips #000 screwdriver to remove the three 2.4mm screws located across the top of the track pad assembly.
  8. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 8、 1の画像 1
    • Use your finger to gently pull up on the assembly and slide a metal spudger under each of the two strips of tape and peel them off of the main metal plate.
  9. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 手順 9、 1の画像 1
    • Slide the track pad assembly up towards the motherboard until it can be lifted up and out.
終わりに
作成者
4人の作成者と共同で作成されました。
Travis Vo
メンバー登録日: 01/27/17
426 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S22G7
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 1,040
