メインコンテンツにスキップ
Acer Chromebook CB3-111-C8UB Back Panel Removal
必要な工具と部品
  1. Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: 手順 1、 2の画像 1 Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: 手順 1、 2の画像 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Back Panel Removal: 手順 2、 3の画像 1 Acer Chromebook CB3-111-C8UB Back Panel Removal: 手順 2、 3の画像 2 Acer Chromebook CB3-111-C8UB Back Panel Removal: 手順 2、 3の画像 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Back Panel Removal: 手順 3、 2の画像 1 Acer Chromebook CB3-111-C8UB Back Panel Removal: 手順 3、 2の画像 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
終わりに
作成者
5人の作成者と共同で作成されました。
Travis Vo
メンバー登録日: 01/27/17
426 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S22G7
4 メンバー
12のガイドは作成済み
コメント 1 件
When I removed the screws from the bottom (Step 1), the 8 screws closest to the hinge were 7mm, and the front 4 were 5mm. Hope this helps someone in the future.
lumberjackdavid - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 1,680
