メインコンテンツにスキップ
Acer Chromebook C740-C4PE Touchpad Replacement
必要な工具と部品
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 手順 1、 3の画像 1 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 手順 1、 3の画像 2 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 2、 1の画像 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 3、 1の画像 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 4、 3の画像 1 Acer Chromebook C740-C4PE Touchpad Replacement: 手順 4、 3の画像 2 Acer Chromebook C740-C4PE Touchpad Replacement: 手順 4、 3の画像 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: 手順 5、 2の画像 1 Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: 手順 5、 2の画像 2
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 6、 1の画像 1
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 7、 2の画像 1 Acer Chromebook C740-C4PE Touchpad Replacement: 手順 7、 2の画像 2
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 8、 2の画像 1 Acer Chromebook C740-C4PE Touchpad Replacement: 手順 8、 2の画像 2
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: 手順 9、 1の画像 1
    • Remove the touchpad from the device.
終わりに
作成者
1人の作成者と共同作成されました。
Jacob Kahn
メンバー登録日: 10/17/17
273 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 7
今までの合計 292
