はじめに
When an Acer Chromebook C740-C4PE screen does not function as it should (including black circles, colored lines, black screen, etc) the best solution is to replace the screen with a new one. This guide helps you to remove the old screen with all of the components that hold it, and install the new screen and secure it.
必要な工具と部品
Turn off the Acer Chromebook, remove it from the charger, and disconnect the battery adapter.
3 の人々がこのガイドを完成させました。
