メインコンテンツにスキップ
Acer Chromebook C740-C4PE Heatsink Replacement
必要な工具と部品
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 手順 1、 3の画像 1 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 手順 1、 3の画像 2 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 手順 1、 3の画像 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: 手順 2、 2の画像 1 Acer Chromebook C740-C4PE Heatsink Replacement: 手順 2、 2の画像 2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: 手順 3、 2の画像 1 Acer Chromebook C740-C4PE Heatsink Replacement: 手順 3、 2の画像 2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: 手順 4、 1の画像 1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: 手順 5、 1の画像 1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: 手順 6、 1の画像 1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: 手順 7、 1の画像 1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Dylan Tocci
メンバー登録日: 10/17/17
237 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G4
3 メンバー
12のガイドは作成済み
コメント 1 件
What type of thermal paste is best used?
Tracey Arria - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 354
