メインコンテンツにスキップ
Acer Chromebook C720-2848 Trackpad Replacement
必要な工具と部品
  1. Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: 手順 1、 2の画像 1 Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: 手順 1、 2の画像 2
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 Trackpad Replacement: 手順 2、 3の画像 1 Acer Chromebook C720-2848 Trackpad Replacement: 手順 2、 3の画像 2 Acer Chromebook C720-2848 Trackpad Replacement: 手順 2、 3の画像 3
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 Trackpad Replacement, Battery: 手順 3、 3の画像 1 Acer Chromebook C720-2848 Trackpad Replacement, Battery: 手順 3、 3の画像 2 Acer Chromebook C720-2848 Trackpad Replacement, Battery: 手順 3、 3の画像 3
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848 Trackpad Replacement: 手順 4、 2の画像 1 Acer Chromebook C720-2848 Trackpad Replacement: 手順 4、 2の画像 2
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848 Trackpad Replacement: 手順 5、 1の画像 1
    • Take out battery by lifting it up in the manner pictured.
  6. Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: 手順 6、 2の画像 1 Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: 手順 6、 2の画像 2
    • Remove 9 trackpad screws. They will be of two different varieties.
    • Make sure to keep these screw separate from those in the previous steps.
    • On the back of the trackpad, there is a plastic film that will cover some of the screws. Simply pull it back (do not pull if off) to remove the screws.
  7. Acer Chromebook C720-2848 Trackpad Replacement: 手順 7、 2の画像 1 Acer Chromebook C720-2848 Trackpad Replacement: 手順 7、 2の画像 2
    • Remove the trackpad ribbon cable.
    • To do this, lift the small black component; it is hinged to the white component.
    • Then simply pull the ribbon cable out of the connector.
  8. Acer Chromebook C720-2848 Trackpad Replacement: 手順 8、 3の画像 1 Acer Chromebook C720-2848 Trackpad Replacement: 手順 8、 3の画像 2 Acer Chromebook C720-2848 Trackpad Replacement: 手順 8、 3の画像 3
    • Remove the small metal frame by simply lifting it out.
    • Carefully peel up the tape holding the trackpad in place.
    • Remove the trackpad from the computer frame.
    • Make sure to watch for any wires or other components and ensure that they are out of the way when removing the trackpad.
終わりに
作成者
1人の作成者と共同作成されました。
Richard Schmidt
メンバー登録日: 03/19/18
337 ポイント
2のガイドは作成済み
チーム
Baylor, Team S3-G1, Williams Spring 2018 Baylor, Team S3-G1, Williams Spring 2018人のメンバー
BU-WILLIAMS-S18S3G1
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 642
