はじめに
This guide explains how to remove the battery. Before removing the battery, the front panel assembly will also need to be removed. Once the battery is reached, you will need to unplug some cables and unscrew some screws.
必要な工具と部品
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
