メインコンテンツにスキップ
Acer Chromebook C720-2103 Solid State Drive Replacement
必要な工具と部品
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: 手順 1、 2の画像 1 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: 手順 1、 2の画像 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 2、 1の画像 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 3、 1の画像 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 4、 2の画像 1 Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 4、 2の画像 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 5、 2の画像 1 Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 5、 2の画像 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: 手順 6、 1の画像 1
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 7、 3の画像 1 Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 7、 3の画像 2 Acer Chromebook C720-2103 Solid State Drive Replacement: 手順 7、 3の画像 3
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Matthew Holt
メンバー登録日: 10/17/17
633 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 UMass Dartmouth, Team S66-G3, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S66G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 275
