はじめに
This guide explains how to properly remove the fan of the Acer Chromebook C720-2103. It can be referenced for temporary removal, while replacing another component, or for the fans replacement. This is a moderately hard replacement, requiring the removal of the battery first.
A fan replacement may be necessary if the device is experiencing unexpected shutdowns due to overheating.
- Be extremely gentle while handling internal components of the device, most are very fragile.
- Make sure the device is powered off during this replacement. There is a possibility of electrocution.
必要な工具と部品
Shut the device off.
Turn the device over so the bottom is facing up.
Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
ある他の人がこのガイドを完成しました。
