はじめに
This guide is to assist in the removal and replacement of the Solid State Drive (SSD) of the Acer C720 Chromebook. Before beginning, be sure the device is completely drained, as it is dangerous to work on the device internals while the device is running. Also, remember to handle the device internals with care, as they are fragile and can be broken.
必要な工具と部品
Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
5 の人々がこのガイドを完成させました。
2 件のコメント
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - 返信
Mi duda es como instalo Chrome os a la ssd nueva
