メインコンテンツにスキップ
Acer Chromebook C710-2833 Speakers Replacement
必要な工具と部品
  1. Acer Chromebook C710-2833 Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Speakers Replacement: 手順 2、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 2、 2の画像 2
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Speakers Replacement: 手順 3、 1の画像 1
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 Speakers Replacement: 手順 4、 1の画像 1
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 Speakers Replacement: 手順 5、 3の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 5、 3の画像 2 Acer Chromebook C710-2833 Speakers Replacement: 手順 5、 3の画像 3
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 Speakers Replacement: 手順 6、 1の画像 1
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 Speakers Replacement: 手順 7、 3の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 7、 3の画像 2 Acer Chromebook C710-2833 Speakers Replacement: 手順 7、 3の画像 3
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 Speakers Replacement: 手順 8、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 8、 2の画像 2
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 Speakers Replacement: 手順 9、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 9、 2の画像 2
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 Speakers Replacement: 手順 10、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 10、 2の画像 2
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 Speakers Replacement: 手順 11、 1の画像 1
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 Speakers Replacement: 手順 12、 1の画像 1
    • Remove the four 3 mm Phillips #00 speaker screws.
    • Note that these screws have an especially large diameter head.
  13. Acer Chromebook C710-2833 Speakers Replacement: 手順 13、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 13、 2の画像 2
    • Using the opening tool, gently pull out the connector that connects the left speaker to the motherboard.
    • Lift, but do not completely remove the speakers. They are still attached by wire.
  14. Acer Chromebook C710-2833 Speakers Replacement: 手順 14、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 14、 2の画像 2
    • Using the opening tool, gently pull the two connector flanges holding the large ribbon cable.
    • Gently pull the large ribbon cable to disconnect it.
  15. Acer Chromebook C710-2833 Speakers Replacement: 手順 15、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 15、 2の画像 2
    • Use an opening tool to remove the head of the last connected ribbon cable.
    • With your hand, grasp the pull tab and disconnect the ribbon cable.
  16. Acer Chromebook C710-2833 Speakers Replacement: 手順 16、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 16、 2の画像 2
    • Using the opening tool, gently pull the connector flange connecting the small wires.
    • Gently pull the black connector from the cream-colored connector to disconnect the wires.
  17. Acer Chromebook C710-2833 Speakers Replacement: 手順 17、 1の画像 1
    • Remove the 3mm #00 Phillips screw near the bottom of the blue board.
  18. Acer Chromebook C710-2833 Speakers Replacement: 手順 18、 3の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 18、 3の画像 2 Acer Chromebook C710-2833 Speakers Replacement: 手順 18、 3の画像 3
    • Using the opening tool, gently pry the main circuit board out of the casing.
    • Gently tilt the main circuit board up.
    • Place the circuit board to the side.
    • The circuit board is still connected at the hinge top left, do not attempt to remove it.
  19. Acer Chromebook C710-2833 Speakers Replacement: 手順 19、 2の画像 1 Acer Chromebook C710-2833 Speakers Replacement: 手順 19、 2の画像 2
    • Remove the black tape over the wire, holding it in.
    • Remove the wire from under the hooks keeping it in place.
    • The speakers and wires are now ready to be removed, and new ones installed.
終わりに
作成者
4人の作成者と共同で作成されました。
Ethan DeRuby
メンバー登録日: 09/24/17
298 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G6, Harley Fall 2018 IUPUI, Team S1-G6, Harley Fall 2018人のメンバー
IUPUI-HARLEY-F18S1G6
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 602
