Remove the 6 mm Phillips #00 screw that holds the back cover on.
Carefully lift the cover off.
Place the cover and screw safely to the side for now.
Using the spudger or your finger, slide the battery release slider and hold in place as shown.
When reassembling, holding of the slider is not needed.
While holding the slider, pull out the old battery.
Remove the two 3 mm Phillips #00 screws located on the WiFi card.
Pop the wires off the WiFi card.
Tilt the WiFi card up and remove it by pulling.
Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
Gently pull the ribbon cable out.
Remove the Solid State Drive.
Use a soldering iron to de-solder the nodes shown on the SD Card Reader. There will be 11 nodes above (see the wide red rectangle), and one node on each side (see two red squares).
Remove and replace the SD Card Reader.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
