はじめに
RAM provides programs with quick access to the data they need. The more programs you have open at once, the more RAM your computer will need.
パーツ
パーツは必要ありません。
  1. Place the laptop on a flat surface with the bottom side facing up. Place the tip of a spudger or finger into the hole on the battery release slider.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Use the spudger to move the slider to the right and hold it there. With the slider held, use your other hand to pull the battery back away from the laptop.
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. This step will void your device warranty.
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  5. Slide the back panel towards you. The best spots to place your fingers are on the bumpers. Lift on the front edge to remove the panel.
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  6. Pull the metal tabs sideways away from the memory stick. The RAM stick will pop up.
    • Pull the metal tabs sideways away from the memory stick.
    • The RAM stick will pop up.
  7. Pull the RAM stick up and away from the laptop. Pull the RAM stick up and away from the laptop.
    • Pull the RAM stick up and away from the laptop.
まとめ
9 の人々がこのガイドを完成させました。
Bradley Pavy
メンバー登録日: 2013年09月30日
1,116 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-3, Forte Fall 2013 Cal Poly, Team 13-3, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G3
5 メンバー
7のガイドは作成済み
Is there only one RAM stick? My wife's C710 has 2 GB of RAM and I have two spare 2 GB sticks. I assumed that the C710 had two 1 GB sticks. Is this incorrect? Are two 2 GB sticks not going to help?
Garrett Mick - 返信
I believe the C710 comes with a single stick of RAM preinstalled, but there are two slots there. So if you have the correct type of RAM, you should be good to go. One installs right on top of the other.
Jeff Suovanen -
Awesome, thank you!
Garrett Mick - 返信
Acer and Crucial insist that 4 GB is maximum ram, but I’ve successfully installed 12 GB and I’ve read reports on the web of 16 GB. It uses the same memory as my 2012 Mac Mini, (my source for the additional RAM) Adding a SSD will make this a powerful machine indeed. The main limitation is that although it will run the (aging) Chrubuntu (an Ubuntu install running on the Chrome kernel), it will not dual boot with linux. The firmware needs to be flashed in order to install a newer linux distro (Gallium OS or a specialized Mint 18), and this will effectively end it’s ability to run Chrome (although I beleive the firmware can be re-flashed so as to return it to Chrome OS .)
cuvtixo - 返信
I want to change the ram stick up to 16 GB ram stick.
How?
flip - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 43
今までの合計 11,271
