メインコンテンツにスキップ
Acer Chromebook 15 CB5-571-C09S Screen Replacement
必要な工具と部品
  1. Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: 手順 1、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: 手順 1、 2の画像 2
    • Wedge one of the plastic opening tool in the inside of the screen cover and run it along the inside perimeter of the screen.
  2. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 2、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 2、 2の画像 2
    • Wedge the plastic opening tool inside the back of the screen cover and run along the perimeter of the screen.
  3. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 3、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 3、 2の画像 2
    • Remove the screen cover from the screen.
    • Pry off a pair of small covers at the back of the hinges first.
    • Carefully grab the edges of the screen cover from opposite ends and pull off the screen towards you.
  4. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 4、 3の画像 1 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 4、 3の画像 2 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 4、 3の画像 3
    • Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen.
    • Be sure to unscrew the inner screws attached to the screen and not the outer screws.
  5. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 5、 1の画像 1
    • Grab the edges of the screen and pull it out towards you.
    • Do not try to remove the screen from the device at this point. There are still connections in the back that need to be disconnected before the screen can be removed.
  6. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 6、 1の画像 1
    • Take out screen from top part of the device and lay it down flat on the key board.
  7. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 7、 3の画像 1 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 7、 3の画像 2 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 7、 3の画像 3
    • Remove the screen connector from the back of the screen.
    • The screen connector is a "plug" that is connected to the back of the screen with a grey wire.
    • The screen connector is attached to the back of the screen with a sticker.
    • Peel and remove the sticker connecting the screen connector to the screen.
  8. Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 8、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Screen Replacement: 手順 8、 2の画像 2
    • Lift the screen back up from the keyboard and remove from the device.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sakiynah Howard
メンバー登録日: 10/17/17
1,000 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017人のメンバー
UMASSD-SIMCOCK-F17S1G3
3 メンバー
12のガイドは作成済み
コメント 1 件
Where can I find the replacement screen?
Riccardo Rigamondi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 2,017
