メインコンテンツにスキップ
Acer Chromebook 15 CB5-571-C09S Battery Replacement
必要な工具と部品
  1. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 2、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 2、 2の画像 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 3、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 3、 2の画像 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 4、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 4、 2の画像 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: 手順 5、 3の画像 1 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: 手順 5、 3の画像 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: 手順 5、 3の画像 3
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 6、 3の画像 1 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 6、 3の画像 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 6、 3の画像 3
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 7、 2の画像 1 Acer Chromebook 15 CB5-571-C09S Battery Replacement: 手順 7、 2の画像 2
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sakiynah Howard
メンバー登録日: 10/17/17
1,000 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 UMass Dartmouth, Team S1-G3, Simcock Fall 2017人のメンバー
UMASSD-SIMCOCK-F17S1G3
3 メンバー
12のガイドは作成済み
2 件のコメント
Where do you get the plastic opening tools
Kelly Robledo - 返信
Instructions were perfect. Used a putty knife to pry off the back
Naomi Harrison - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 22
今までの合計 4,066
