メインコンテンツにスキップ
Acer Chromebook 15 C910-C453 Speakers Replacement
必要な工具と部品
  1. Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: 手順 1、 2の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: 手順 1、 2の画像 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 2、 1の画像 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 3、 2の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 3、 2の画像 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 4、 2の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 4、 2の画像 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 5、 1の画像 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: 手順 6、 3の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: 手順 6、 3の画像 2 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: 手順 6、 3の画像 3
    • Before beginning hard drive replacement, the back cover should be taken off and the battery removed to ensure no power is connected.
    • Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
    • Gently pull black ribbon out.
  7. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 7、 3の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 7、 3の画像 2 Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 7、 3の画像 3
    • Disconnect the black wires where the speakers are connected to the motherboard by pulling down on both sides with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 8、 2の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 8、 2の画像 2
    • Gently pull the right speaker, FYHZRF-R, upward, unlatching it from its 2 rubber joints.
    • Repeat with left speaker, FYHZRF-L.
  9. Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 9、 2の画像 1 Acer Chromebook 15 C910-C453 Speakers Replacement: 手順 9、 2の画像 2
    • Lift left and right speakers up and untangle the connecting wire from the metal notches.
    • Remove the speakers.
終わりに
作成者
3人の作成者と共同で作成されました。
Jacob Rakestraw
メンバー登録日: 04/17/17
419 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S15G1
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 612
