はじめに
Use this guide to replace the speakers.
必要な工具と部品
Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
Sixteen 5mm Phillips screws located around the border.
Two 5mm Phillips screws located in center.
Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
Gently pull black ribbon out.
もう少しです!
終わりに
