メインコンテンツにスキップ
Acer Chromebook 15 C910-C453 Battery Replacement
必要な工具と部品
  1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: 手順 1、 2の画像 1 Acer Chromebook 15 C910-C453 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Battery Replacement: 手順 2、 1の画像 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Battery Replacement: 手順 3、 2の画像 1 Acer Chromebook 15 C910-C453 Battery Replacement: 手順 3、 2の画像 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Battery Replacement: 手順 4、 2の画像 1 Acer Chromebook 15 C910-C453 Battery Replacement: 手順 4、 2の画像 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Battery Replacement: 手順 5、 1の画像 1
    • Remove the battery.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jacob Rakestraw
メンバー登録日: 04/17/17
419 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S15G1
5 メンバー
11のガイドは作成済み
コメント 1 件
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
Thomas Revell - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 26
今までの合計 10,090
