メインコンテンツにスキップ
Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
必要な工具と部品
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 手順 1、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 手順 1、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 2、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 2、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 2、 3の画像 3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 3、 2の画像 1 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 3、 2の画像 2
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 4、 2の画像 1 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 4、 2の画像 2
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: 手順 5、 1の画像 1
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ryan M
メンバー登録日: 01/30/20
213 ポイント
1ガイドが承認済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 18
今までの合計 696
