メインコンテンツにスキップ
Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
必要な工具と部品
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 手順 1、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 手順 1、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 2、 2の画像 1 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 3、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 3、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 3、 3の画像 3
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 4、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 4、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 4、 3の画像 3
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 5、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 5、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: 手順 5、 3の画像 3
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Thomas Carling
メンバー登録日: 01/30/20
552 ポイント
4のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 916
