メインコンテンツにスキップ
Acer Chromebook 14 CB3-431-C7EX Battery Replacement
必要な工具と部品
  1. Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 手順 1、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 手順 1、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • There are several clips holding the cover in place.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 手順 2、 3の画像 1 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 手順 2、 3の画像 2 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 手順 2、 3の画像 3
    • Use a spudger to disconnect the battery's connector from the motherboard. The connector should slide out toward the battery.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 手順 3、 2の画像 1 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 手順 3、 2の画像 2
    • Use a Phillips #0 screwdriver to unscrew the two 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: 手順 4、 1の画像 1
    • While lifting the connector side of the battery, slide the battery towards the center of the laptop.
    • Be mindful of the tabs on the bottom of the battery housing (shown in picture). These need to be underneath slots when reinserting the battery back into the laptop.
    • Remove the battery from the laptop.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Thomas Carling
メンバー登録日: 01/30/20
552 ポイント
4のガイドは作成済み
コメント 1 件
clear and concise
good instructions
battery can be found for less than half that cost online
mapatouli - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 59
今までの合計 1,782
