メインコンテンツにスキップ
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
必要な工具と部品
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: 手順 1、 2の画像 1 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: 手順 1、 2の画像 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: 手順 3、 2の画像 1 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: 手順 3、 2の画像 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 4、 2の画像 1 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 5、 1の画像 1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: 手順 6、 2の画像 1 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: 手順 6、 2の画像 2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 7、 3の画像 1 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 7、 3の画像 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
終わりに
作成者
6人の作成者と共同で作成されました。
Jessica Beckford
メンバー登録日: 02/12/18
527 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S15G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 187
