はじめに
Use this guide to replace the SSD on your Acer Aspire A515-46.
必要な工具と部品
If laptop is not already off, hold power button for 5 seconds until screen shuts off.
Using a Philips head screwdriver, remove all of the screws on the back panel.
Use a small screwdriver or prybar to pry the back panel away from the laptop.
Using your fingernails, pinch the battery connector on both sides and pull it straight back until it is removed from the socket.
Use a small Philips head screwdriver to remove the screw holding the bottom of the SSD.
Insert the new SSD into the socket, making sure that the notch is on the right side of the SSD.
ある他の人がこのガイドを完成しました。
